03-22-2023
03:27 PM
03:37 PM
I can't see the full frame of the 35mm negative using the Canon Auto Bellows and Canon Duplicator. I am using a 50mm Canon Macro lens. The frame is cropped. I tried every aspect ratio as well. I even reversed the lens to no avail. I have posted a photo of the set up with the lens reversed, but I still can't see a full frame with the lens in the normal position. What am I doing wrong?
03-22-2023 03:35 PM
Why are you using the lens backwards? For the T7 at least, You are using a crop-frame camera, so you will only get the APS-C sized portion at 1:1. I don't know why it does not work on the R.
I had no problems without the bellows with my APS-C camera, EF-S 60mm lens and 2x2 slides.
03-22-2023 04:17 PM
Hi, I did not try it on the R, I forgot that the T7 crops it. THANK YOU THANK YOU THANK YOU. I will try when I get home..........
03-22-2023 03:35 PM
03-22-2023 04:17 PM
