02-20-2023
07:50 PM
12:00 PM
Which adapter do I need to use the bellows and duplicator with EF and RF lens?
02-22-2023 09:24 AM
Hi, Munari!
So that the Community can help you better, we need to know exactly which Canon lens you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
02-22-2023 10:46 AM - edited 02-22-2023 10:48 AM
Canon only made bellows for FL and FD mount cameras and lenses. There are some 3rd party bellows for EF cameras and lenses.
Which bellows do you have? Which camera, and which lens do you want to use it with?
02-22-2023 11:10 AM
Hi.
I have a EOS R and an EOS T7. I have an EF 50mm macro and an EF 100mm macro. I have a c Canon Mount adapter EF-EOS R. I have a vintage Canon Bellows FL and Slide Duplicator.(This came with a %%mm Ring adapter). I want to connect the Bellows and slide duplicator to either the T7 or the R.
I very much appreciate your assitance.
Gene Munari
02-22-2023 11:20 AM - edited 02-22-2023 11:31 AM
What you are asking for does not exist. No one has made adapters to put EF lenses on an FD mount.
Your best bet is to buy a 3rd party EF bellows that maintains electrical communication.88E2CD0F-B8ED-4747-9FB7-F64715C038F6.jpeg
02-22-2023 11:24 AM - edited 02-22-2023 11:25 AM
I believe the FL mount bellows is not compatible with EF and RF mount camera bodies. I recommend that you look for EF mount bellows, which may very likely cost more than either of your cameras.
[EDIT] Another option would a tilt-shift lens for the EF mount.
02-22-2023 11:50 AM
Thanks for your reply, but let me simplify the question. I am not trying to use the auto focus function of the lens, I am just trying to connect the camera to the bellows and slide duplicator. I can do the focus manually and set the aperture and shutter manually as well. Has to be some adapter or method.
02-22-2023 12:18 PM
I guess you're thinking of achieving something like this, but as has been said, there's no existing adapter to connect FD mount equipment to an EF or RF mount camera.bellows.jpg
There are, however, slide duplicator attachments available on Amazon or Ebay that simply screw into the filter thread of your macro lens. Something like this, for instance.
Would this do the job for you?
02-22-2023 12:22 PM
This will work. Does it scan 35mm negative strips as well? What is the name of the slide duplicator?
02-22-2023 12:23 PM
What is the brand and model number of the bellows (in blue)?
