EOS R8 Battery life is ridiculously short
Eaglesnest
Enthusiast
The battery life on my new R8 is ridiculously short. After a full charge, it shows low battery power after just a few of shots. Is there any reason why? Thank you for the tips.
25 REPLIES 25
@Eaglesnest wrote:
I tried "View finder" only. Not in favor for that. Which is better Auto 1 or Auto 2?
Which is best to use is entirely a matter of personal preference.  Experiment.
I believe #2 will only use the EVF, provided you keep the rear display fully closed and turned away from you.  This is how I usually store the camera.  When you open the display the exposure and AF point will switch to the rear screen.
I like the “Live” version of the [Q] button display, without any sensor image.  It is a habit I developed from my using DSLRs, instead of using the tiny LCD display on the top of the camera.
It's not about whether the battery is in the camera, it's literally how hot it gets.  Leaving a charged laptop or camera in the sunlight in a car on a hot day is a bad idea; leaving just the batteries, if they're at 100%, would be just as bad.
bama924
I do not have a solution, I just want to add to your issue, because I have the same problem. These batteries are the same batteries that were used for my t7i and t8i and they lasted all day if not longer. I am a sports photographer and will shoot between 5000-6000 per day. Now that I have the R50 I will get a half day out of the new battery at most. It is not the battery, it is the camera.
EOS R50 has preview AF enabled by default. This is a huge drain on the battery. I suggest you disable it to improve battery life significantly.
https://cam.start.canon/en/C011/manual/html/UG-06_AF-Drive_0070.html
Brian
bama924
Thank you, I have disabled it, hopefully that will help, if not I carry 3 batteries with me at all times.
noirfilm
The R8 viewfinder uses more battery current than the screen.  Try setting display performance to power saving.
