12-24-2023
10:14 AM
08:10 AM
The battery life on my new R8 is ridiculously short. After a full charge, it shows low battery power after just a few of shots. Is there any reason why? Thank you for the tips.
12-25-2023 10:53 AM
@Eaglesnest wrote:I tried "View finder" only. Not in favor for that. Which is better Auto 1 or Auto 2?
Which is best to use is entirely a matter of personal preference. Experiment.
I believe #2 will only use the EVF, provided you keep the rear display fully closed and turned away from you. This is how I usually store the camera. When you open the display the exposure and AF point will switch to the rear screen.
I like the “Live” version of the [Q] button display, without any sensor image. It is a habit I developed from my using DSLRs, instead of using the tiny LCD display on the top of the camera.
12-26-2023 04:12 AM
It's not about whether the battery is in the camera, it's literally how hot it gets. Leaving a charged laptop or camera in the sunlight in a car on a hot day is a bad idea; leaving just the batteries, if they're at 100%, would be just as bad.
01-08-2025 08:04 AM
I do not have a solution, I just want to add to your issue, because I have the same problem. These batteries are the same batteries that were used for my t7i and t8i and they lasted all day if not longer. I am a sports photographer and will shoot between 5000-6000 per day. Now that I have the R50 I will get a half day out of the new battery at most. It is not the battery, it is the camera.
01-10-2025 04:53 AM
EOS R50 has preview AF enabled by default. This is a huge drain on the battery. I suggest you disable it to improve battery life significantly.
https://cam.start.canon/en/C011/manual/html/UG-06_AF-Drive_0070.html
01-10-2025 07:24 AM
Thank you, I have disabled it, hopefully that will help, if not I carry 3 batteries with me at all times.
12-23-2025 10:03 PM
The R8 viewfinder uses more battery current than the screen. Try setting display performance to power saving.
