Cables for EOSR50
TH57
Hello,
I just purchased an EOSR50 and was wondering about what the best cables for connecting it to my computer. I see it has a usbC and a mini hdmi. I'm thinking the mini hdmi out could be for tethering for either webcam use and possibly downloading photos? USBC would be for downloading photos.
Manly I'm wanting to connect and download photos but the web cam aspect could be cool, too.
Any links for these?
thanks!
5 REPLIES 5
Stephen
Moderator
Moderator
Links to third-party sites are not allowed.
You can find all of the official accessories for your EOS R50 here: https://canon.us/R50accessories
Please be sure to review the Community Guidelines: https://canon.us/CommunityGuidelines
kvbarkley
Canon's streaming software uses the USB-C.
You use the USB-C for transferring data and tethering.
HDMI would be used for displaying on an external monitor or HDMI capture on your Computer
**(with a special HDMI capture device)
stevet1
TH57,
If you want to do a wired connection from your computer to your camera to download photos, you use your USB connection. Your manual should give you recommendations for the cable to use.
I have always had good luck following the recommendations in my manual. Sometimes, people who try and use third-party cables have not had good luck.
Steve Thomas
USB is a data connection.  You would use this for things like transferring files, including photos / videos.  (Although I personally would transfer files by plugging the memory card into my computer, using a card reader as required.)
HDMI is a video signal connection.  You can use this for sending a video signal to another device, like a monitor or an external recorder.  This will show basically what's on your camera's LCD, or whatever video you're currently shooting.  It can not be used for transferring things you've previously shot.  The video signal can be captured on a computer for webcam or streaming, if you have an HDMI capture device.  You can buy these online quite cheaply; mine cost about £20.  Note that if your computer has an HDMI port, that is almost certainly an output, not an input.
