12-22-2024 04:16 PM
I have a Canon EOS R7 and have very recently received an RF 200mm-800mm lens which is right heavy. I do wildlife photography (where a tripod is useful when I know the habits of my creatures) and am looking for advice on a decent tripod with a quick release attachment so I more efficiently attached and disconnect the camera without the screw it on drill.
It would also be nice to have a matching monopod compatible with the attachment device for the camera/tripod as I originally thought a monopod would give me the extra help with a bit more flexibility.
I am still learning the easiest way to adjust the telephoto, hold the camera, AND keep the subject in my sights.
12-22-2024 07:08 PM
I have a couple of Manfrotto 055 carbon fibre tripods with various heads including the Manfrotto 410 geared head. The tripods have lasted me well and continue to be solid. I have also got a Manfrotto carbon fibre monopod though I can't remember the model.
Most quality tripods have interchangeable heads with a standard 3/8-inch thread, so you can often mix and match legs and heads even from other brands. I know of several photographers who have Wimberley heads on Manfrotto "legs". In general the arca swiss quick release mount is more popular across various brands of tripod head, though Manfrotto has their own quick release plates and even some with area swiss.
12-30-2024 07:04 AM
I went with a carbon fiber tripod with a published weight limit of 44 pounds and a total carrying weight of 3.1 pounds. It won’t arrive til the end of Jan 2025 so my final assessment of it is pending. Also opted to forego a center post. For the 200-800mm lens, I bit the bullet and got a Wimberly gimbal. My preference f
12-23-2024 07:05 PM - edited 12-23-2024 07:08 PM
I am using a Benro aluminum monopod, which cost under $100 USD. The carbon fiber version is lighter by a small amount. I use a Kirk MPA-2 tilt head. It has a very good friction control. My Sigma 150-600mm doesn’t flop around.
The tripod is an older Benro Series 3 75mm combination tripod. I can install a 75mm flat plate, a 75mm center column, or a 75mm bowl as seen in the photo.
B&H has a house brand, Robus, that I suspect is made by Induro/Benro. When my model was discontinued, nearly identical products appeared under the Robus brand name. It’s a tree trunk.
The ball head is a Really Right Stuff BH-55. This head has zero backlash. What’s that?
Have you ever tried to photograph the Moon, only to have the lens shift as you tighten it down? That’s backlash. This head stays exactly where I point it, even with a few pounds of weight that is leaning off center.
12-23-2024 07:31 PM
Thank you! Benro appears to be a well-regarded brand. I will call a dealer and ask questions about heads on monos for long lenses v tripods. Hoping for interchangeability. My husband informed me he built gimbals (who knew?!!) so we will be jointly researching those v gear heads
Love asking the community. So many great ideas to research
