07-27-2025 04:38 PM
Hey Guys, fast question, I'm probably overthinking it, but what is the full name of the battery grip for the Canon R5, I'm noticing the battery is draning faster when I'm doing longer shoots, and was wondering if the battery grip will help.
Thanks
07-27-2025 06:00 PM
For the EOS R5 the BG-R10 is the battery grip, it can take two batteries to double the number of pictures that can be captured.
For the EOS R5 Mk2 you need the BG-R20. This grip can also be used with the original EOS R5.
More info here.
https://cam.start.canon/en/H002/accessory_0140.html
07-27-2025 06:00 PM
More info here.
07-27-2025 06:03 PM
Thank you so much ill get the Bg r10 for the canon R5 next month and a second battery
