EOS R5 compatibility with LP-E6P battery
MMThomason
Can the new LP-E6P battery be used in the EOS R5 (original R5 not Mark II) without issues?
2 REPLIES 2
johnrmoyer
It works for me.
https://www.usa.canon.com/support/canon-product-advisories/Firmware-Notice-EOS-R5-Firmware-Version-2...
Firmware Notice: EOS R5: Firmware Version 2.1.0
Firmware Version2.1.0 incorporates the following fixes and enhancements:
1. Enables functions to be used without limitation in conjunction with the new Battery Pack LP-E6P. This makes it possible to shoot at the same continuous shooting speed as when using LP-E6NH. In-camera charging of LP-E6P is also supported.
2. Adds [Protect Images] and [Rating] during FTP Transfer.
3. The following issues have been fixed:
    a. Fixes an issue, in which when Wi-Fi is disconnected, Err70 occurs.
    b. Fixes an issue, in which when shooting subjects that are smaller in the frame, the card access indicator blinks and operations can no longer be performed.
    c. Fixes an issue, in which when performing shooting in high-speed continuous shooting + mode with the [Highlight Tone Priority] option set to [ON], focus may not be achieved when certain ISO speed settings are used.
If the camera's firmware is already Version2.1.0, it is not necessary to update the firmware.
Thank you!
