xc15 lens
JohnRobert1
Hi, I want to buy the canon xc15 4k camera to shoot independent shorts.  Might be a bone headed question but which wide angle lenses compatible with it?
3 REPLIES 3
Waddizzle
The XC15 does not allow for interchangeable lenses.  It uses an integrated zoom with a 35mm equivalent range of 27.3-273mm
Canon XC15 Support Page
If you wish use interchangeable EF mount lenses, then you need to look into the digital cinema cameras from Canon, instead of a professional digital camcorder.  The C100 is in the price range of the XC15, but it does not offer 4K video.
Thank you for your reply.  I would like to shoot high-quality footage for broadcast on a budget whats my best options?  The c-100 or xc15 or another around $2,500?  already have t5i not great.
Hello JohnRobert1,
The best camera if you're wanting to shoot high quality broadcast footage on a budget then the XC15 would be the best choice.  It gives you more recording flexibility with regards to the image quality.  You can also add either a wide angle adapter or telephoto adapter to this camera to extend the range of the lens.
Both the Canon WD-H58W wide converter and Canon TL-H58 tele-converter lens are compatible.
Friends and Family
