08-20-2020 03:01 PM
I set up an OBS streaming "studio" and I've noticed that my XF400 was squeezing its image (into 720x486) for some reason. I was able to get it back to 1080 by switching the priroity setting in the menu to External HDMI, but it seems really strange that having it on a normal settings would somehow squeeze the HDMI down like that. Is there something I'm doing wrong, or is that just how it is with these cameras?
08-22-2020 12:56 AM
Hi there,
Usually the HDMI connection will automatically detect the connection and send an appropriately sized signal through it, but it may have detected something different via the HDMI connection or potentially just read the connection to OBS inaccurately. Generally if you connect the camera to a television or directly to a monitor/recorder, you will get a signal of the same resolution as your camcorder setting.
08-22-2020 01:06 AM
It's going into a Blackmagic capture card via HDMI. I couldn't figure out why the image would appear squeezed in OBS and the only thing that fixed it was switching the camera to External Priority.
Anyway, it just seemed strange. I'll keep experimenting with the other settings. There is a HDMI max resolution setting as well that I didn't look at.
