07-26-2021 01:53 PM
I've looked over the specs for the Vixia HF R800 and can't see a maximum storage capacity listed anywhere.
After a bit of trying (I was looking at the wrong menu option) I've managed to get the camera recording onto a 512 GB that's actually a microSD in an adapter.
Sort of out of curiosity but also because I'd almost be tempted to buy one, does anybody know whether the camera can record onto 1 TB?
Without knowing much about hardware, I'd be tempted to believe that there is no constraint in terms of the plug in memory capacity. But perhaps I'm wrong about that.
07-26-2021 04:12 PM
Not sure. While the card would be formatted the same, it's possible that the operating system in the camcorder wouldn't be able to fully address/access all locations on the card.
I have to ask though, would you really need a card capable of capturing 64 hours of footage (in the highest quality codec)?
Also the standard tip to avoid micro-SD cards as they can cause trouble with DSLRs, camcorders and other equipment that has full-sized SD card slots.
