The Canon Final Cut Pro 7 capture plugin suddenly stopped working properly
dovey13
For years I have been using the Final Cut Pro capture plugin with no trouble. Suddenly, it has stopped mounting footage properly. Has anyone experienced this, or suggest a fix?
Situation:
- footage mounts, but only audio is able to be previewed in the log and transfer window
- clips fail to import
- the footage file structure is in tact, as it can be imported on other machines
- FCP log and transfer works fine with panasonic footage
I have tried:
- reinstalling the plugin, even different versions
- reinstalling Final Cut Pro 7
- reinstalling the mac OS
Thanks
2 REPLIES 2
dovey13
Situation:
I have tried:
Thanks
What is your video format of your original format? If they are MXF, then you can update your FCP 7 to FCPX, now the FCPX can support MXF files nativately without rewrapping.
