07-20-2020 08:15 PM - edited 07-20-2020 08:19 PM
Hi gang,
I did this back in 2008 with my first GL2 (just picked up a new-old stock one) with a different operating system and machine.
Not finding any software that will work with Windows 10, 64 bit. Any ideas on how I can hook the camera up to an HP 1520t machine and run the tape into the computer? I know I can use the conversion boxes, but the resolution is lower than the output of the camera.
I've seen where this question was asked about 4 years ago re using a laptop. Is there anything I can add, hardware wise, to my PC that will enable me to upload the DV tape without losing resolution and sound quality?
Thanks!
07-24-2020 12:53 AM
Hey there,
To get the best quality capture from this camcorder you would need to import it the old fashioned way using a Firewire cable and video capture software or a video editing program with a live capture feature. Since most computers don't come standard with Firewire ports anymore you will likely need to purchase a USB capture device with a Firewire port and a Firewire cable. The Firewire port on your camera is a 4-pin port and most capture devices will have an 8-pin Firewire port but you will want to doublecheck because some will have the 4-pin instead.
On the software side, most video editing programs will have a live capture option, but I suspect livestreaming software like OBS Studio would likely have an option to record the live feed as well.
07-24-2020 12:53 AM
Hey there,
07-25-2020 07:43 AM
I apprecieate your reply and thought that's what I would have to do.
In the meantime, I forgot that I have an old desktop tower that has Windows XP! It's in storage and I should be able to run the old Canon software on that system.
Thanks again.
