03-16-2018 11:24 AM
I have a 500 and bought a lens hood. I have a 43x52mm step ring. Apparently the 500 has a smaller than 43mm thread. What size is it really? Thanks.
EvanG
03-16-2018 12:59 PM
The lens size is 43 mm diameter but if it will not fit because threading is not a standard one, maybe the one you have is not a metric specs.
03-16-2018 01:08 PM
I'm not sure I understand. Is 43 mm not a metric measurement?
EvanG
03-16-2018 03:29 PM
Maybe the one you have is not a metric thread.
When you buy did specify an inside diameter of 43 mm?
03-16-2018 04:04 PM
Yes. That's what was so puzzling. It says 43-52mm on the ring.
EvanG
03-17-2018 08:52 AM
Maybe you will need an adapter ( 43 mm inside diameter ) where in you will fit that lens cap to that adapter.
I supposed when you buy the cap it must include the adapter together.
