02-27-2016 12:38 AM
I'm trying to find a way to output video while shooting with the VIXIA HF M301 video cam. The manual only explains how to playback after recording. I'm hoping someone has found a way to monitor video while shooting. Any help?
02-27-2016 11:00 AM
Have you tried to connect to a monitor using either the HDMI or component out cables? You shouldn't have to change any settings to be able to do this.
02-27-2016 01:31 PM
Thank so much. I've only tried connectiong with the yellow video cable. I'm assuming by compent cables you mean the RGB colored cables. I haven't tried that either. I'll try that and if it doesn't work I'll go out and get an HDMI cable. I'll let you know how it goes. Thanks again for your help.
Lane
02-27-2016 02:46 PM
Yes, I did mean the Red, Green, and Blue connectors.
In order of quality from highest to lowest:
HDMI - audio and video in one cable
Component - (Red - Green - Blue) needs a separate connection for audio
Composite - (Yellow - Red - White) Yellow is usually video while red and white are left and right audio channels.
Glad to be of help. Let me know which one you get to work for you.
