04-05-2025 08:17 PM
Hello, I have been using a canon vixia hfr80 camcorder and today the screen went black. Didnt drop it but the screen is staying black and not working. I have power it off and changed the battery and still nothing. I can hear the start up sounds and other sounds when pushing a button but I cant see anything on the screen. Anyone delt with this before or know a solution?
04-07-2025 07:06 PM
Greetings dylan888,
Let's check to see if we can get the display to re-appear on your VIXIA HF R80 camcorder. With the camcorder powered on, let's close the LCD against the camera and the swing it open again. Then, tilt the screen 180 degrees to where it is facing the opposite direction and then swing it back to where you can view the display while recording. In case the display is still dark, then we would suggest on sending the camcorder to our facility for repair.
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
