10-27-2017 08:15 AM
When recording, the HDMI out sends the control display, not the actual camera signal - this seems wrong. Is there a way to get HDMI out to just send the clear camera signal, so that it can be used for livestreaming through a capture box, for example?
10-28-2017 02:59 PM
You might find this YouTube video useful.
11-03-2017 02:04 PM
The solution in the youtube video does not apply to the hf50, which lacks the menu item cited in the youtube. So - this is still a mystery. And a really annoying one.
11-03-2017 02:42 PM
This is for the HF R50.
Look on page 149 of the User Manual under "Display Setup". There should be an option for turning off "Output Onscreen Displays".
11-03-2017 02:49 PM
11-03-2017 02:59 PM
It may say that in the manual, but that item does not appear on the M50 system setup menu. Went through it several times, did a system reset, it's not there.
11-03-2017 03:05 PM
So there is no option under System setup either? I don't doubt you in the least. I see where the video wasn't helpful for a HF M50 since it applies to the R50. Just surpised the manual for the M50 is wrong. Again, I don't doubt you and wish what I posted would have been helpful. Hopefully someone will join the conversation and give you a definitive answer.
