03-09-2013 12:53 AM
03-11-2013 07:05 PM
Hi Hobbywelder,
If you're shooting movies of arc welding, we recommend against the use of these camcorders unless you have protective shielding. The sensors can be damaged by the lighting.
From your description, I'd take a look at the VIXIA HF R400. This is a fairly simple camcorder capable of using SDXC memory cards.
The VIXIA HF R40 and VIXIA HF R42 add internal memory and wireless connectivity and still remain below the $600.00 threshold you've mentioned. These camcorders should be in your local camera shops soon, if they're not already there.
You may see these camcorders here.
I hope this is helpful.
