Frame rate with the XA30
paulwmiller
Help me out with this if anyone can please.
I understand the shutter speed should be double your frame rate. So when shooting at 30 frames/second, I should be using 60 for a shutter speed. Shooting at 60 frames/second, it should be 120. The problem is the Canon XA30 shutter speed adjusts from 1/60, 1/100, 1/250, etc. How do you get to 1/120 or do you just use 1/100 because it 's the closest you can get?
I'm really trying to get smoother pans at 60 FPS.
Thanks!
~Paul
1 REPLY 1
Tim
paulwmiller,
As a general rule of thumb, you want the shutter speed double the frame rate but it's approximate.  So you want to get as close as possible, in this case 1/100th would be suitable.  Slower shutter will give you smoother motion when playing back, so I don't think you will have any trouble using 1/100th.
Friends and Family
