03-17-2014 06:51 PM
I want to connect two camcorders to a HDMI video switcher and output to HD Monitors and to a computer and use capture software such as Adobe Premiere Pro to capture video and sound. Of course, the computer will have a HDMI video capture card.
03-17-2014 07:09 PM
Yes, that should work. The R400 has HDMI output, and unless I am mistaken, on-screen-display output can be disabled.
However, keep in mind that the R400 likes to record with a very fast shutter speed, so in low light the image looks quite grainy. I would recommend using an HD webcam instead if that is an option to you. The older M series cameras are a bit better and also have HDMI output. For that matter, I believe that just about all of Canon's HD camcorders do. Whether or not it will work depends more on the configuration of your other equipment.
03-17-2014 07:09 PM
03-17-2014 10:21 PM
03-17-2014 11:04 PM
02-03-2018 10:37 AM
