09-23-2016 04:22 PM
Is it possible to connect from a Windows based PF (Windows 7 or Windows 10) to the PROGRAF iPF 670 Printer (using a router or other means if necessary)??
09-25-2016 09:11 AM
Hi BryanGraham,
Using the ethernet port on your imagePROGRAF iPF670, you can connect your router to your printer with an ethernet cable and then any computer that accesses your router (either wired or wirelessly) can then use your imagePROGRAF iPF670 over the network connection.
For further assistance, please dial 1-800-423-2366, Monday-Friday 8:00 am to 8:00 pm Eastern Time, excluding holidays. . There is NO charge for this call.
09-25-2016 09:11 AM
Hi BryanGraham,
