05-08-2019 12:03 AM
We recently moved. Before the move my printer connected to the wifi and laptop just fine. We kept the same router etc in the move but the password to the wifi was changed. When I try to reconnect to the wifi it bypasses the screen to input the new password and just tries to connect. Our router only has a reset button on it so theres no way to do the button press way of connecting. I've reset the settings several times, I've tried doing a hard reset and have not been able to get around this.
Windows 10
MG5420
05-08-2019 09:55 AM
Several options to correct this:
You can also change your wi-fi password back to whatever it was previously on the router as well.
05-08-2019 11:48 AM
05-09-2019 01:36 AM
Hi mwilde,
Congratulations on the new move!!! To begin troubleshooting this issue I recommend resetting the network card on the printer then connecting the printer to the network. The following steps will assist you:
Resetting the Network Card:
Wireless Setup via Standard Setup
05-09-2019 07:29 AM
05-10-2019 03:12 AM
Hi mwilde,
The recommended setup (Standard Setup) did not require any actions to be take on the physical router. All steps were performed on the printer itself. Click HERE for additional information on the Standard Setup method previously recommended.
To better assist you, more information is needed. When attempting to connect the printer to your new network, what screen (or the exact message on the screen) appears that is causing the conflict with the setup. Could you also please provide information on what happens during the Advance setup.
05-10-2019 06:54 AM
