04-13-2025
12:10 PM
12:39 PM
I am trying to use the Manfrotto RC Pan Bar LANC Remote Control (MVR901EPLA) with the XF605, but the Iris + and - buttons do not work. I have two of these and neither works, so it is a compatibility problem. Are any steps being taken to fix this problem?
04-13-2025 12:29 PM - edited 04-13-2025 12:48 PM
You'll need to contact Manfrotto in regard to support or compatibility issues with their product. Canon doesn't have any control or influence on manfrotto products, so they are not in a position to ensure they work or are compatible with your device.
Their compatibility chart shows support for Standby, REC, Zoom, Focus, Iris (*1), Rec Review
(1*) Iris compatibility: behavior depends on the camcorder model.
Compatibility-Chart_Manfrotto_Camcorder_April_23.cleaned.pdf
I would suggest
Or Browser Remote if Manfrotto won't help.
04-13-2025 01:36 PM
I understand that this may be a Manfrotto problem, but this function works okay with the Canon XF400 camcorder, so the LANC function of the XF605 must be different from the XF400 which is why I am asking the question on the Canon forum. Any info on this difference would be appreciated.
