01-02-2013 03:59 PM
11-18-2013 01:22 PM
I just brought me new 600 ex speedlite home and had the same problem reported here. I tried holding the two clear buttons down and turning the power switch to lock and presto it now appears to be working fine.
Thanks so much for you help!
11-19-2013 12:40 AM - edited 11-19-2013 12:51 AM
Thanks HCGraham. Doing This indeed helped for me. AFTER I also tried 5 packages of batteries...etc...
11-19-2013 10:54 AM
01-04-2014 11:46 PM
Is there some issue with this.. I just got mine as well.. Opened it and tried 3 different brands of batteries.. nothing.. Then turned on, opened lid closed it,. nothing.. then moved the arm up and down then it started to work.. Very odd..
01-09-2014 11:32 AM
I too experienced this problem and solved it with the tips on this forum.
Is this a recurring problem with an individual speedlight?
Has anyone seen this happen again once it has been fixed?
01-09-2014 11:39 AM
mine only did it the first time. and my unit always sits without the batteries cause i use them for a lot of different things (rechargables).
Simon
02-01-2014 10:25 PM
I am back. Cannot get 600EX-RT to recognize new batteries. Gives dead battery indicator. Any other suggestions? Send back to B&H for replacement? Very, very dissappointing. Even if it starts working I do not trust the flash to work when I need it.
02-19-2014 01:50 AM
I bought the 600EX-RT a year ago, hardly used it and when I really needed it, the no battery symbol appeared and the flash won't work... I've replaced the batteries and followed all the advice posted on this forum, Very disappointed and frustrated. Please help
02-19-2014 01:56 AM
@atomskitchen wrote:I bought the 600EX-RT a year ago, hardly used it and when I really needed it, the no battery symbol appeared and the flash won't work... I've replaced the batteries and followed all the advice posted on this forum, Very disappointed and frustrated. Please help
did you try letting the batteries sit in the unit for some time (while off)? that worked for me, think it was a few minutes - ever since then it has worked without problems. but it seemed like it need to fill up a capacitor, charge an internal battery or something.
02-19-2014 02:10 AM
Thanks, I have tried....nothing
