01-02-2013 03:59 PM
12-16-2014 02:15 PM - edited 12-16-2014 02:17 PM
Solution Summary
Steps to Resolve Speedlite 600EX-RT Low/Change Battery Issue:
Details
After recently purchasing a new Canon 600EX-RT in preparation for a family portrait session, I was eager to get the Speedlite out of the packaging and onto a stand for some test shots before packing up and heading off for a weekend with my extended family.
I grabbed a package of fresh batteries, loaded (4) AA's, secured the battery cover, attached the provided SCH-E1 Color Filter Holder and powered on the Speedlite expecting to see the default factory settings on the 600EX-RT's main LCD display.
Instead I was greeted with a blank LCD and the Low/Change Battery symbol.
I was fairly sure that the batteries that I'd selected were unused, but I usually unpack batteries from their shipping material and add them to a larger container of batteries, so it was possible that used batteries had somehow made their way into the group or that some number of the batteries were simply too old. I set aside the batteries in question and tried another group of four batteries.
I was more than a little disappointed when I was again greeted with the Low/Change Battery symbol. I was fairly certain at this point that the batteries were not the issue, but just be sure I tried a third set of batteries with the same result.
I quickly searched for an online resource that might help me troubleshoot and resolve the issue and found this Canon Support forum thread.
The problem state and the proposed resolutions seem to be inconsistent and involve variations of some or all of the following:
Unfortunately, none of the proposed solutions resolved the issue for me. So I gave Canon support a call and to see if this was a known issue.
I described the behavior to the support engineer and at first he too was stumped, suggesting that perhaps this was a defective device. He offered me several options for either returning or repairing my new 600EX-RT.
I was hoping for a more immediate resolution AND based on the large number of people reporting this same behavior (here in this thread) I suspected that there might be a Canon support advisory (perhaps only available to Canon support personnel) with information describing the issue along with a resolution that did not involve returning or repairing the device.
I asked the support engineer to check and he kindly agreed. After a few minutes on hold he came back and said there was in fact a support advisory that described a similar problem, but it involved the color filter holder. As previously mentioned, I had installed the color filter holder shortly after unboxing the flash.
I was dubious at first that the filter holder would cause the Speedlite to malfunction, but hoped he was right.
I performed the steps as indicated and the Speedlite 600EX-RT powered on correctly. I placed the filter holder back on the device and power-cycled the flash a few more times, and each time the Speedlite came back up as expected.
Upon closer inspection you see sensors near the top of the flash unit and just underneath the bottom clasp of the color filter holder, as well as what appears to be a small magnet in the bottom clasp of the filter holder. These sensors are used by the EOS system to determine when the filter holder is attached to the flash unit and assist in white balance calculations when using Canon supplied filters.
For a more detailed explanation of the color filter's form and functions alongside an EOS camera, google 'Speedlite 600EX-RT SCH-E1 review'.
For a copy of the advisory google 'Canon Issues Speedlite 600EX-RT Product Advisory'
09-01-2015 02:19 PM
@ai3643 wrote:Tried everything on here, no luck.
Heres my solution that worked for me,
It really seems to be a battery connection problem. All I did after messing with moving the switch back and forth, playing with the clear buttons, nothing worked.
I just opened the battery lid, wiped the battery contacts and battery ends with my finger, and shut it. Now it works. Maybe just luck. Just using normal Durcell batteries.
My Duracell batteries tend to leak ... that can be a real mess if you leave them in the flash and they corrode the contacts inside your flash. For this reason, I ALWAYS ALWAYS ALWAYS eject single-use batteries when I'm done for the day. It's also the reason I strongly prefer rechargeable NiMH batteries (I use Panasonic Eneloops and have had only positive experiences with these.)
09-01-2015 03:49 PM
09-01-2015 09:01 PM
The gel holder should not be left on the speedlite if you are not using a gel.
10-08-2015 08:20 AM
It's true!! After not using my new flash for months because of the battery cross issue and trying everything on here, it just had to take the plastic diffussor filter off of the top of it and voilá! Works like the expensive thing that it is. I actually joined the forum just to write this!!
04-12-2016 02:29 PM
04-13-2016 08:01 PM
Gald to hear you got it fixed. It is cold comfort to those of us with out of warranty 600ex-rts to know that yes indeed there actually is a problem and not user error or our imaginations. Tis the 'curse of the eary adopter'...
05-05-2016 12:17 AM
Thank you all. This was very helpful (when I finally read enought of the posts). I came to the forum several different times and tried the clear buttom and power switch method several times, but only a couple times each time. When I read that it takes several times I poured a glass of wine and settled in. It took me upwards of 10 times plus, but it is working again!!!
10-13-2016 07:51 PM
10-13-2016 09:11 PM
I wish Canon would give us a trade in credit for our 600EX-RTs.
03-30-2017 02:35 AM
I just read on the Canon website to power it down, detach the colour filter holder (the plastic cover that fits in fromt of the flash and holds the lottle colour filters) and then power it up and oh my word it works!!!
