Speedlite 430EX and canon 7D wireless
Osx
I try my speedlite 430EX wirelessly using my Canon 7D to go off through the flash menu. Now that all works but when I make a picture in the mirror I see the internal flash on the picture. Is it not true that the internal flash to go off a little earlier.
2 REPLIES 2
p4pictures
I have seen similar myself with other master flashes set not to fire as part of the exposure.
My take is that as the master flash (pop-up on your 7D) needs to send the pulses of light to the slave flashes then it is still emitting a low level of light due to the tail-off effect. It had to send the "fire now all you slaves" command right before the shutter opened, or even as the shutter opened. Hence it shows up in a mirror, but actually it's usually of such a low level that it won't impact the picture.
Brian
Brian
7D5D
Rising Star
If  I'm understanding your question correctly...
This might be stating the obvious but double check to make sure your built-in flash is set only for triggering a remote flash and not for built-in flash + external flash.
Flash Control menu
Built-in flash func. setting
Wireless func.
- middle icon (Speedlite only)
Now your camera will fire a pre-flash to trigger your exterior Speedlite without the pre-flash as part of your exposure
