08-29-2023 09:59 PM
Aloha,
I recently upgraded our old Canon 50d to a Canon r6 and my husband found his old speedlite 430EX flash in storage. We were wondering if it was compatible to the new camera. It fits in the flash zone fine but we couldn’t get it activated and haven’t found anything online other than 430EX II discussions.
Any help or advice would be appreciated.
Mahalo,
Alina
08-29-2023 10:09 PM - edited 08-29-2023 10:21 PM
"but we couldn’t get it activated"
What do you mean by that? Does it fire if you press the Pilot Lamp Test button? The 430EX should work with the R6, since the 430EXIII-RT is listed as an accessory in the R6 manual.
08-30-2023 10:09 AM - edited 08-30-2023 04:41 PM
Older EX series speedlites work on newer cameras. But there are NOT compatible with the in camera flash menu. What do you mean by "couldn't get the flash activated". Is the pilot light on. Does the speedlite's LCD screen say "E-TTL" or "TTL". If it says "TTL" the speedlite is NOT communicating correctly with your camera. Also flash photography IS NOT COMPATIBLE with the Fully electronic shutter. Use mechanical or electronic first curtain shutter. As a test set the camera to One Shot AF. Then put the lens cap on. The speedlite should emit a series of strobe burst (Intermittent Flash Firing) from the main flash tube. This is what's called an AF Assist Beam. The IR Grid Pattern is NOT compatible with ANY mirrorless camera. This test shows that the flash does work. The camera needs to be set to One Shot AF. For this test to work the AF Assist Beam doesn't work with Servo AF.
08-30-2023 01:03 PM
Thank you, I will be trying these suggestions today and updating the forum!
08-31-2023 11:56 PM
And just to be sure, are you using an R6, or an R6 Mark II?
