08-06-2023
05:17 AM
09:32 AM
Do you have a Canon EL-1 or EL-5? And any of these cameras: R3, R7, R8, R10, R6 ii or R50?
If so, wonder if you can help me?
Is your camera, RF lens and Speedlite capable of Auto Focus Bracketing with flash? Most camera/flash combinations default to electronic shutter mode in Auto Focus Bracketing mode and are not compatible with use of flash. This Canon document (https://cam.start.canon/en/H001/supplement_0010.html, as of May 2023) suggests there the EL-1 does work with some newer R cameras.
If anyone is able to check, I would really appreciate it.
The function is enabled in the Red 6 menu (on my R10).
08-06-2023 08:43 AM - edited 08-06-2023 09:01 AM
I've removed this from the spam quarantine. It likely was flagged because the link doesn't work. I edited it (the comma was included).
08-06-2023 10:50 AM
No flash photography IS NOT compatible with focus bracketing. This is due to the use of the fully electronic shutter.
08-06-2023 12:26 PM
Thanks for your reply. I should reluctantly accept your explanation. I only question it because the Canon document (linked above) does suggest that the EL-1 works with several newer Canon R models (including my R10!)?
08-06-2023 12:41 PM
Canon's mirrorless cameras work with flash photography with full mechanical shutter. Or electronic first curtain shutter. But flash photography IS NOT COMPATIBLE with the fully electronic shutter.
08-06-2023 07:59 PM - edited 08-06-2023 08:00 PM
The link you posted says focus bracketing is compatible with EL-1 and R3 (firmware 1.2.0), exclusively.
08-06-2023 08:03 PM
Yes that is true. That's why I told the OP it was NOT possible with their camera. The R3 is the only one that currently supports it. With the EL-1 speedlite I'm not sure about the EL-5 though.
08-06-2023 09:24 PM
I looked at this earlier too. Couldn't find anything definitive about the EL-5 but I suspect it the same as the EL-1. FEB is only supported on the R3 with FW 1.2.0 or later.
08-07-2023 03:49 AM
Thanks. I was confused by the Canon document which lists several compatible camera models (R3, R7, R8, R10, R6ii & R50) only to exclude them in the footnotes!
(1: This feature is supported exclusively on the EOS R3 with firmware ver. 1.2.0 or later.
08-07-2023 09:45 AM - edited 08-07-2023 09:45 AM
Feature requests can be made from the Canon USA website.
Canon Homepage | Canon U.S.A., Inc.
Click [+]Feedback at the top, then Product and leave your request.
