EOS 60 D & Speedlight 320 EX - Function setting error w radio flash trigger DSLRKIT
guil
Hi - I am trying to trigger the 320Ex via the above radio trigger (cheap stuff). Although the DSLRKIT transceivers seem to be communicating (the green lights illuminate when I press the test buttom), the 320ex will not fire. The external flash func setting menu tells me that either the flash is incompatible or the the flash's power is turned off. The flash power is not off and it is fully charged. I believe the adapter mounts on the transceivers are well seated in the 60D and the speedlight. Perhaps the DSLRLKIT does not support the 320 EX ?? (I was told it does, but i do not trust the person who told me this..). Can someone help ??? Thank you
0 REPLIES 0
