10-19-2022 08:17 AM
I have a 600EXii-RT problem that I can't figure out. I changed the batteries and now the unit powers on normally, but won't flash, even with the test button. I had been using it for a few hours prior to the battery change and it worked perfectly. No settings on the unit or my camera (5DM4) were changed during the battery swap. I did try replacing the batteries again (they are new and fresh) but to no avail. There are no error messages active on the flash or camera, and the ready light stays red. The flash unit is a few years old, but has less that 500 flashes on it, very seldom used. Any ideas would be greatly appreciated.
10-19-2022 05:07 PM
Hi Dakota59 does the pilot light turn on when the speedlite is turned on. What kind of batteries are you using rechargeable or Alkaline batteries. I also own the 600EX II-RT and found the flash doesn't like rechargeable batteries due to the lower voltage. Rechargeable AA batteries only put out 1.1 or 1.2 volts while Alkaline batteries put out 1.6 volts.
-Demetrius
40D, 5D IV, EF 16-35mm F/2.8L III, EF 24-70mm F/2.8L II, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT & 600EX II-RT
10-19-2022 05:57 PM
Thanks for responding deebatman316. I am using alkaline batteries, all new and fresh. And if by pilot light you mean the flash ready light, yes, it is on. It doesn't go green at start up though like it used to, just stays solid red. All other functions work and the display looks like it should be flashing. I am very confused.
10-19-2022 06:08 PM
Are you able to test the speedlite on a different camera body. Do other functions of speedlite work ie the AF Assist Beam.
-Demetrius
10-19-2022 06:22 PM
I don't have another camera body to work wit. What's concerning is I should at least be able to fire a test flash off camera and it won't even do that.
Ron
10-19-2022 06:26 PM
Will the speedlite fire the modeling flash if the depth of field preview is pressed.
-Demetrius
10-20-2022 10:54 AM
It won't flash when I press the DOF button either, and it is enabled.
10-20-2022 11:57 AM
Do you have another speedlite to test on that camera.
-Demetrius
10-20-2022 12:14 PM
What camera body are you using?
Does the flash function properly when it is not on the camera body?
10-20-2022 03:16 PM
I have a 5D Mark IV.
