430ex II output won’t adjust in manual mode
mberhardt
I have 2 430ex II flashes.  I’ve used them for years with out issues.  One of them will not not adjust the output in manual mode. It stays at full power.
When I compare the two flashes to each other.  The only noticeable difference is on the one not adjusting output, it has the C.fn showing on the screen.
 I’ve attempted changing the B C.fn settings. Does not seem to impact a change.  I can’t figure out how to turn off C.Fn’s.
I have no idea if that’s what’s causing the challenge or if I should be trying something else?
1 REPLY 1
Anonymous
Not applicable
Could be set for wireless slave mode?
Avatar
click here to view the press release
