Circular Polariser Samples.
Grazie
Rising Star
Hello Canonites! Polas came up recently so I wanted to show what I get.
See the “flash” reflection of Sun on Background leaf:
Now with the Pola doing its stuff:
10 REPLIES 10
John_
Personally, I like the non-filtered shot. The colors look deeper and it has better all-around detail. The filtered shot looks flat to me.
My samples were only to show what can be achieved using a Pola with maybe, unwanted Flash. And yes, doing that has made the layers look flat. Good points. Thanks John.
You're welcome Grazie! It did remove that brightness in the foreground
Erm... I was hoping for people to see the redux of shiny reflection on the Background leaf?
Interesting.  Compare and contrast.  I have stopped using CP filters.  They seemed to have a negative impact on AF.
Hi - What were you getting?
I wonder if the second shot was taken with the same settings - it looks either like it is out of focus or has insufficient DoF...
cheers, TREVOR
Hi. Manual everything and I only twisted the Pola. I was demonstrating how the shine was removed using the Pola.
Soft images.  I was getting soft images from the EF 100-400 f/4.5-5.6L IS II USM lens.  I was shooting birds-in-flight, BIF, photos with brightly lit, partially cloudy skies.  I wanted to capture some of the detail in the clouds.  It is not that the shots were OOF, because in a way they were.  The sharpest part of the images were where the locked and active AF point was located.
The images were just simply not razor sharp.  I tried a couple of different bodies with pretty similar results.  I had tried a 6D, 1D4, and a 7D2.  Of course, I captured different shots with each camera, but the results were consistent.y soft, with the sharpest area being the acting AF point.
That is when I noticed the protective CP filter and removed it.  Problem solved.  Now, the only filters I use on my lenses are Clear filters.  With the exception of an ND filter, you can reproduce the effects of most filters in post.  ND filters can dramatically alter your exposure, not your image.  You cannot alter the exposure in post, just the resulting image.
