Canon MF3010 Scanner not showing on Windows 11
ggori
I just bought and installed a Canon MF3010. It works fine as far as printing, I also have an MF260 Series at another location.
My windows settings shows both printers/scanners. The MF260 shows the "Scanner settings" and was scannning OK.
The MF3010 does NOT show the "Scanner settings".
The help from Windows says: "Not all scanners are compatible with Windows protected print mode. To see if a scanner is compatible with Windows protected print mode, see Mopria certified products."
However, I do NOT have Windows Protected Mode.
When I start the windows Scan application, it finds the MF260, but not the MF3010.
What to do?
0 REPLIES 0
