06-20-2023 01:20 PM
Our 7550 was having trouble pulling pages through so I replaced the rollers. Now it won't pull them at all. It starts to, then it sounds like the page is getting stuck on something, possibly the retard rollers, then I get the message that No page was found in the feeder with the error code -4401. I've checked all the rollers, I've cleaned all the glass and sensors, I've tried the count only trick (same thing). The tray rises, it starts to pull the paper, the paper shakes sometimes, then it just gives up. Any ideas?
09-14-2023 10:21 AM
did you ever get this resolved? if so, how, i am having the same issue but on different model.
thanks...tina
05-31-2024 01:47 PM
No. I ended up buying another scanner, same model--11 months later and the same problem started happening. I just did a search to see if this has been talked about any more and found my original post. Sigh.
Cody
05-31-2024 01:51 PM
Thanks for joining the conversation, Cody!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
