CanoScan LiDE 400 Scans not saving w/ScanGear
Djinn252
I just set up my Canoscan LIDE 400, and in basic testing, I'm running into an unusual problem.  It scans - but doesn't save anything.  I changed the default save folder, and as it scans, I see a temporary file appear, like ~SG_SRC.TMP.
I would expect this to resolve into a normal file upon completion, but it doesn't.  And as soon as I exit the ScanGear software, the temp file disappears.  How do I get ScanGear to save the image?  Thank you.
Hi Djinn252,
Please open the IJ Scan Utility.  In the lower right corner, click on the Settings button.
You can change the location of where scans are saved here.
For example, if you are using the ScanGear button, click ScanGear on the left side of Settings.  Change the "Save In" to your desired folder.
More information can be viewed here:
https://ij.manual.canon/ij/webmanual/ScanUtility/W/LiDE%20400/1.1/EN/SU/su-114.html
4 REPLIES 4
Tiffany
Moderator
Moderator
Welcome to the Canon forum!
So that the Community can help you better, we will need to know
 exactly which operating system is running on your computer (i.e. Windows or macOS and which version) Any other details you'd like to give will only help the Community better understand your issue.  If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you!
Djinn252
Just to round out the details, I'm running a Windows 10 system.
Djinn252
I'm making some headway here ... The issue was that I'd defined the folder for temporary files.  But I can't find the setting that allows me to define where scanned images are to be saved.  I want all scans, all types, to be saved to one specific folder.  Where can I find this setting?
Hi Djinn252,
Holiday
