CanoScan LiDE 300 Scan to a Subdirectory Within a Directory
JIBBO
HOW DO YOU SCAN TO A SUB DIRECTORY WITHIN A DIRECTORY.
FOR EXAMPLE I HAVE A DIRECTORY CALLED SCANNED WITH SUB DIRECTORIES UNDERNEATH IT.
I HAVE NOT FOUND A WAY TO SAVE MY SCAN IN THOSE SUBDIRECTORIES. HELP WOULD BE APPRECIATED.
I HAVE THE LIDE 300 SCANNER
ROBERT
4 REPLIES 4
ArthurJ
What version of Windows or MacOS are you running?
JIBBO
WINDOWS 10
I WAS ABLE TO FIND A WAY TO DO IT BUT IT WAS MUCH EASIER WHEN I HAD LIDE 100.
Thanks for the information about your OS and we're glad to hear your figured out a solution.  If you could share your findings here, it could help other users who might be running into the same situation.  We'd really appreciate it!
JIBBO
HERE IS HOW I DID IT
1. CLICK ON SETTINGS
2. CLICK ON CUSTOM SCAN
3.IN SAVE SETTINGS UNDER SAVE IN ENTER PRIMARY FOLDER
4. IN APPLICATION SETTINGS SELECT SEND TO A FOLDER
5. SELECT ADD
6.WHEN DIALOG BOX APPEARS SELECT ADD
7. FILE EXPLORER WILL APPEAR
8. SELECT SUB FOLDER TO SCAN TO.
9. WHEN THE DIRECTORY SHOWS UP IN BLUE SELECT ADD
     IF IT IS ALREADY THERE JUST SELECT IT.
10. CLICK ADD.
11. CLICK OK.
12.CLICK CUSTOM SCAN AGAIN.
13. CLICK OK.
SCAN SHOULD START.
