04-14-2017 09:47 PM
Hello I've been having troubles recording with my camcorder and now it just gives me the cannot record on this memory card message every time I try to. I've changed the SD card multiple times even reformatted some to see if that was the problem but It didn't seem to help. I also made sure that it wasn't manually locked. Has anyone had this problem if so could you fix it? If you did could you please share with me, how you did it. Thank you 🙂
04-14-2017 11:51 PM
What brand, size, type, speed SD card are you using? What recording settings are you using?
04-15-2017 02:07 PM
well im using sandisk SD Cards and ive tried a 16,32, and 64gb. the speed of them im not sure. For the rcording settings I have the movie format as AVCHD and the video quality on FXP
04-15-2017 07:54 PM
Hi Litt1e_cesar,
I think VideoGeek is on the right track.
Your camcorder will accept the following memory cards:
While we don't recommend specific brands or models of cards, we do recommend that you use a memory card produced by a major manufacturer that closely adhere to the current industry standards. You may see the standards at sdcard.org.
We recommend against the use of cards that require an adapter to fit in the camcorder (i.e. micro-SD or Mini-SD). The increase in the number of connections between the camcorder and memory card (from the memory card to the adapter, then from the adapter to the camcorder) makes a malfunction more likely.
Finally, your camcorder does not support memory cards using the UHS-I or UHS-II standards. While these cards should be backward compatible with older memory card standards, not all of them will work. Please check with the card manufacturer for details regarding backward compatibility with the Speed Class 10 or Speed Class 6 card standards.
If the memory cards you're using already meet these specifications, I recommend that you contact our technical support team. For contact options, please use this link: http://Canon.us/ContactCF
08-10-2017 05:33 PM
