05-28-2017 03:06 PM
HI all,
I purchased a Vixi HF G40 and was told I could use it to livestream through my computer. I can't figure out how to do it. I feel as if thegre is a menu setting that I am missing.
It doesn't work via HDMI at all (the internet says HDMI on a computer is out only, so that makes sense.
I connect via USB and have it the on/off swicth set to "camera," and windows doesn't recognize it at all.
I connect and turn it to "media" and the windows thinks its a disk drive.
Any advice would be most appreciated.
Thanks,
Jack
05-30-2017 01:09 PM
You may need a video capture device to livestream with the VIXIA HF-G40. The capture device would go between the computer and the camcorder. As has already mentioned, ask the person who told you this how it can be done. There are some video capture cards that have an HDMI in port.
05-29-2017 11:08 AM
Did the salesperson tell you that? I would go ask that person. I do not know if the model can do "live stream" or not. I do know that my son and his wife somehow turned their HF-G62 into a baby cam, so they can monitor the baby's crib from anywhere on the house on their iPhones.
05-30-2017 01:09 PM
05-30-2017 01:17 PM
Thanks everyone. I spoke to canon and I do, indeed, need a video cature device. I was simply misinformed.
I've purchased one and hopefully things will work as I want.
Jack
09-04-2017 09:56 PM
Sir:
Would you please recommend a video capture device for my Vixia HF G40. I am attempting to figure out how to stream on Facebook. So far no luck.
Thank you,
David
07-20-2018 12:09 PM
07-20-2018 03:21 PM
What capture device do you have? What have you tried so far? Be as specific as possible.
07-20-2018 04:06 PM
When I connect the camera to a monitor I have no problem getting a picture.
I have two different capture devices. The first one is -
Electop Video Capture Devices HDMI to USB 3.0 Full HD Live Video Capture Game Capture Recording Box Dual HDMI USB 3.0 Adapter Video & Audio Grabber for XBOX PS4
When I connect the camera to the compture via this device I can find the device in OBS but it does not give a picture. It also does not display anyting on the monitor.
The second device I have is the elgato HD60S. When I connect the camera to this device it does NOT find it in OBS and it does not find a picture in the software download for the device.
I have tried my DLSR camera with both devices and it will pick it up for streaming. I cannot get it to find the Vixia HF G40 video camera. I have tried changing the FPS on both the camera and OBS and I am still having no luck.
The HDMI Status on the camers just has lines on both the video and audio output.
07-21-2018 09:18 AM
I've had good luck with the Magewell capture device:
https://www.bhphotovideo.com/c/product/1105735-REG/magewell_xi_100_d_usb_hdmi_one_hd_hdmi_usb.html
07-21-2018 02:32 PM
What did you do to get it to wor? Did you change any of the setting on the camera?
