RE: C100 Dual slot recording to HD and SD simultaneously: Where can I learn how to do this?
gregposchman
I cant seem to find instructions in the manual or online for recording HD and SD simultaneously to  two SD cards.
Is this possible and How can I do it?  THanks!
1 REPLY 1
Tim
Hello gregposchman,
Wen recording with the EOS C100, you can choose to use the double slot recording method.  This makes the camera record the same clip to both cards, in the same format, not one in HD then another in SD.  We are sorry for any inconvenience that this may cause you at this time.
If this is an urgent technical support inquiry, please consider contacting Canon technical support directly.  You can do so through our web site.
