11-28-2016 12:31 AM
Hi!
A Canon Vixia M40 was mounted on a large tripod that somehow fell over. Fortunately, the camera appears to be fine, however the screen has somehow become bent away from the the axis that allows it to flip.
I was wonder if I should attempt to fix this bend or just let it go as it doesn't appear to hinder functionality.
Thanks!
Autolooper
11-30-2016 03:38 PM
Hi Autolooper,
Thank you for posting.
If you've thoroughly tested your camcorder, including zoom functions, button & switch operations, etc, I recommend that you keep using it.
If you determine that repairs are required at a later point, you may setup the repair of your camcorder at this site: https://www.usa.canon.com/repair
12-01-2016 12:20 AM
Thanks for the resonse!
Further inspection and use has revealed that there's a larger gap between the screen's pivit point and the camcorder, the screen is also looser than it used to be. Other than that, it appears to be fully functional.
