11-05-2015 12:14 PM
I mostly use PL mount lenses but occationally would like to use the lighter weight EF lenses for Ronin and other rigs. I can't seem to find any adapters to go from EF to PL. Plus I need it to be rock solid... not a rigged fix that might cause issues.
Thanks!
01-04-2017 10:40 AM
Keep looking. A quick web search turned up this thing.
Triad Canon C300 Camera EF to PL Lens Mount Adapter
01-04-2017 05:11 PM
Hello Donthepro,
I understand that you'd like an adapter to go from PL to EF. At this time no such adapter direct from Canon exists, unfortunately.
There are options (which I am sure you're probably aware) to have Canon factory service centers switch the mounts on the camera from PL to EF and back again, provided that you either supply or purchase the applicable mount. I understand this is not the same as having an on the fly adapter, but it would be the option we have available at this time for the camera to accept either lenses independently.
01-05-2017 08:54 AM
@Tim wrote:Hello Donthepro,
Tim has hit the nail on the head. The basic problem is that the camera has a PL mount, instead of EF, because there are a host of pl to EF adapters out there, but not the other way around.
