CR-N300 Recording Video Via Remote Camera Control App
Hellobum
Does the Remote Camera Control Application support recording video from the cr-n300?  The option is grayed out when I try to use it.  Not sure if a setting was missed
8 REPLIES 8
The Remote Camera Control App should allow you to control and monitor one or more cameras on your network.  If the option is grayed out, something on your network might be blocking communication. Start with basic connectivity.  Can you ping it?  Can you log into its webserver?
In addition to the IP interface, the CR-N300 can also connect by Wi-Fi. This allows the operator to access the camera's Settings Page from a wireless tablet device that is equipped with a supported HTTP browser. When using multiple cameras at the same time the user can set and operate the other cameras in the same way by inserting the assigned IP address of the camera in the web browser of the tablet or other device. In addition, the CR-N300 is equipped with an infrared remote controller, which is also used to controller the camera wirelessly.
Other hardware / software applications also exist.
It has serious connectivity options and supports many controller interfaces.  Dual video streams, etc.
Canon Controller RC-IP100
Call Canon support.  I'm sure they would be happy to help.
I can log in fine and control the camera from the software.  I can also get to the web interface to control it.  A few other options are grayed out as well.  I was just needing the option to record from the software instead of having to use rtsp or mounting it as a usb camera to record from it.
Since I do not have a way to reproduce or see what you are working with, is there by chance something more you have to subscribe to in order to unlock additional features?
Support is still an option also.
AFABcamera
Hey! Did you ever find a fix for this? I am facing the same issue. Thanks!
I never found a solution to this. I ended up abandoning this for the project and went a different direction
Ah bummer. I appreciate the reply, thank you very much!
Hello Shadowsport, thank you for your great contribution. I also have the same issue, all recording options on the remote camera controller are greyed out, and can't record anything. i've checked the proxy and it all seems fine. All the initial set up has been done as per the manual too. so can't really understand why it's not working...
doubleJ
Could the recording options be greyed out because the PTZ cameras don't support recording?
If the software doesn't support NDI recording, to the computer, there wouldn't be anything to record.
JJ
Friends and Family
