04-01-2022 11:42 AM - edited 04-03-2022 10:07 AM
Anyone else considering? The R5C was not the road I anticipated taking, but I'm tired of waiting and since this body doesn't overheat, I am more confident about it over the standard R5.
Although I am a stills shooter, the Cinema EOS side of the body is intriguing. Its so much smaller than a C70. I'm not serious enough about video that I'd miss Clog2. The body has 16 14 stops so plenty of DR for my use. Its also not limited to Super35 or 16 (which isn't so much a limitation), but Canon has really stepped up here. I don't care about ibis. All of my lenses except 1 are IS and the body has digital IS built in. I have purchased a bunch of accessories. Control Ring Adapter, 2 512GB CF ExpressB, 2 128GB UHSII, 2x Watson batteries (Canon was out of stock), and I've not tried Manfrotto batteries yet.
Going to try the AngelBird CFExpress cards and ProGrade for the XD Cards. I've always used SanDisk so going to try something else. Both are highly rated.
I also contacted EasyCover in the Netherlands and my contact there has said they do not plan to make a skin for the R5C. Was hoping for this, but am more excited about a new body. Haven't pulled the trigger quite yet. I have a quick business trip and wanted to be back for the arrival. Plan to wait a week. If nothing glaring is reported, I will finally move to mirrorless.
04-14-2022 11:23 AM - edited 04-14-2022 01:02 PM
Hi Rick,
The audio menu items are grayed out regardless of the presence, or not, of an accessory attached to the hot shoe. Canon Tech support, who had encountered the same issue with his copy of the R5c, suggested that there might be an incompatible setting, but I have tried every setting change that I can think of, and it has had no beneficial effect on the grayed out menus. This appears to be a firmware glitch and, since this is the first iteration of this camera I am hopeful that Canon will fix it. The other issue has already been stated, in re the inability to defeat the internal microphone. While a user can delete the tracks produced by the internal mic in post, there remains the issue of headphone monitoring. I will have another look at the Tascam module to see if it allows one to select only the attached XLR mic/s for monitoring.
And with battery supplies non-existent, I've just ordered an 87W power-bank that I hope can be carried in a pocket, or a belt case. I will report back about the ultimate success or lack thereof.
04-14-2022 03:47 PM
The Tascam XLR adapter for the R5c does allow for the isolation of the external microphone source when monitoring via headphones, so the only remaining issues are the grayed out audio menus and the ability to turn off, or defeat the R5c's internal microphone.
04-17-2022 09:58 AM
Good Morning,
I'm hoping Canon will be able to help you with this. At the rate I'm going I'll have a fully accessorized PD kit ready to go before I ever get my body. This does 480mbps transfers and 100w
04-17-2022 11:27 AM - edited 04-17-2022 11:28 AM
Hi Rick,
I occasionally use an Anker 87W PD power-bank with a 6' USB-C to USB-C 100W compliant cable. I shoot mainly outdoors with the R5c, and have had no issues with disconnects. However, I do have some concern with the magnetic connector. I have an older Macbook Pro that has the magnetic power connector that can easily detach if the cable catches onto something. Furthermore, if one intends to leave the male connector permanently attached to the camera, the environmental seal/flap may not close around it. That said, I'm not sure what problem it attempts to resolve?
I should add that the Tascam CA-XLR2d adapter, along with a lightweight Shotgun, is a great addition to the R5c. There remains the issue of the internal microphone, but its recorded tracks can be easily deleted or muted in post, and the Tascam adapter allows one to monitor only its attached microphone. There is an R5c firmware issue, however, and that relates to the grayed out menus on the audio pages, but I personally have little use for the internal mic.
Regards,
Ron
04-18-2022 02:35 PM - edited 04-18-2022 02:45 PM
Hi Rick,
In regards to a power bank:
I have a 6' USB-C-C cable that I use with an Anker 87 Watt PD power bank that hangs down the side of the camera. The power bank is a tad heavy, however, and I am considering the resurrection of a photographer's vest to carry it in. The vest beats carrying it in a pocket, and provides room for other accessories, if required. The magnetic connector looks interesting but, other than the right angle feature, I'm not sure what advantage it offers over a straight connection? Perhaps you can illuminate?
Regards,
Ron
04-20-2022 09:39 AM
Ron,
All good points once again. Not 100% on the use case. It was just something I saw a few people using with a small built up rig. I got my first stock alert from B&H. (No stock) so it looks like its going to be a while for me (still).
Eventually, I will try and do the smallest PD possible, one that provides a decent power to weight ratio. I will never need power for an all day video shoot and will be happy with something that can keep the camera going with a few breaks.
I'm a little disappointed now that I didn't order sooner, and that there isn't enough inventory to meet demand.
04-20-2022 11:13 AM
Hi Rick,
It had been rumored that the next shipment of R5c's would come about on 5/28/22, but I don't know if that is, or was ever a valid statement. As for a lightweight PD supply, I do agree, but ultimately decided that if I had to carry something extra, as in, a PD Power bank, I may as well make it something that has real power. The 87 Watt Anker isn't light by any definition, but it is pocketable, and it fits in just about any of the many pockets on my photographer's vest. I don't plan to use it on a regular basis, as the camera can shoot 8k 30fps with its internal battery, but not for long, and add to that the fact that I shoot mainly 4k to match with my C300, it quickly becomes a non-issue.
I hope that Canon fixes the apparent firmware issue with the R5c before the next release, because as of the current time, almost all of the audio menus are grayed out and inaccessible.
04-21-2022 10:35 AM
Ron,
5/28. Thats what I read as well. Was hoping it wasn't true. I think you will see a FW update, but not until after the next release of body's.
04-21-2022 11:28 AM - edited 04-21-2022 11:28 AM
Actually, since I find the internal microphone of limited value, I don't care when they fix it. That said, it should be corrected in order to make the camera whole. It just shows how slipshod their QC is, since anyone who had bothered to check those menus prior to release would have noticed the deficiency, and it wouldn't have taken an IT genius.
Finally, I am finding this website to be onerous. The insistent survey that pops up every time one logs on and then takes the user to the Canon Store, does not make for a pleasant trip to this site. And the inability to jump to the last page of a topic is also a nuisance. I have made these comments on the survey page numerous times, but I doubt that anyone is even perusing the comments.
04-23-2022 02:31 AM - edited 04-23-2022 02:41 AM
Ron,
You aren't the only one... I posted about it as well.
What is up with the Take A Survey Pop Up? - Canon Community
And I have this page set as a favorite, but agree we should be able to skip to to last page. I guess this thread has about run its course. Surprised its basically just 2 of us here. I'm still going to buy, when its available. Have a nice weekend.
