05-25-2025 03:09 PM
For some reason that I can't seem to figure out, the very bottom of this image doesn't seem to want to finish printing. It's like the printer refused to make a final pass. I've confirmed correct paper types, ICC profiles, etc. Using PPL and Canson Infinity Rag Photographique. Any ideas? First time this has happened to me.
05-25-2025 05:03 PM
Hello
My first thought (question), since this was working for you, is: Are you using a wi-fi connection? From your prior success I would imagine you are not using the Air Print driver.
05-25-2025 07:21 PM
Yep, I am using wifi! Haven't seen issues like this yet, but honestly not familiar with the Air Print Driver? Did I miss something up on install?
05-25-2025 07:48 PM
Well, you don't want to be familiar with the Air Print driver 😞; it's a stripped down version of the full IJ driver.
On to wi-fi, you may find that to be your problem. Graphics take a fair amount of time to travel from here to there and your image shows the telltale indicator. Try using either a USB or ethernet cable. You may have to reinstall the driver for the wired connection. I never have an issue with ethernet between my workstation and printer.
