imagePROGRAF PRO-1100: Fine Art profiles, images washed out
pdub99
I'm not sure if this is expected, but when I use the FineArt profiles (both rough and smooth) in CaptureOne print preview (as well as in the final print), the image is washed out, the colours are muted, etc.  If I select a different profile (say, platinum pro, or luster) everything is (at least closer to) normal.
Is this expected with the Fine Art profiles? The profile matches close to what is printed, but it seems wrong that the image should be altered to that extent.
On a related note, where can I find icc profiles for the 1100 + fine art smooth / rough?  The printer / export pane in Capture One shows them, but I can't select them from the view / edit mode.
0 REPLIES 0
Avatar
