Pro-100: Some colors do not match monitor; some do
rwpatton
New to forum but have reviewed all questions that I can see for 2014 and do not see an answer. I am using Photoshop Lightroom and CS6 and the Pro-100 printer. Monitor is an NEC P221W, calibrated using SpectraSensor Pro. Printing with Canon CLI-42 ink on Canon Photo Paper Plus Glossy II. I have installed the latest XPS printer driver and am confident that I am using the printer with the proper driver. Here's the problem: I cannot get bright blues and greens to print with the same level of intensity that I see on the monitor. As a test, I printed some other photos that consist primarily of portraits, and skin tones and general color are superb. Only my effort to print a photo consisting of green leaves and bright blue flowers with the saturated color of the flowers popping off the paper does not seem to work.
ebiggs1
You are going to need to over saturate the colors you want to exceed the rest of the colors in the photo.
Over the years I have found out a few things that seem imposswible whrn prinitng.  This was true in my darkroom as well as printing digital.
One, it is impossibile to get all the colors to match a monitor.  You can get several to match but not all of them.
Two, the most important adjustments of your monitor is gray-scale, contrast and brightness.
Three, Canon professional photo printers have a tendacy towards a reddish (warm tone) bias.  It is built in.  This is going to make over saturated greens more difficult.
Remember you are looking at and comparing light on a screen to pigmented ink on paper.
2 REPLIES 2
ebiggs1
Thanks very much.
