07-19-2024 06:36 PM
I'm trying to make some prints using the Canon Matte Photo paper. The first print I did came out well, but the rest of my prints are very grainy and washed out. This occurs in both the standalone app and in the Photoshop plugin. What could be the problem? Here's my setup:
Windows 11
Canon Matte Photo Paper (MP-101)
Using Canon Print Studio Pro with these settings:
07-20-2024 02:46 PM
OK, I'm an idiot! I've been printing on the wrong side of the paper! Thanks for the help, John!
07-20-2024 06:27 AM
1. Verify that you are printing on the correct side of the paper. It can be difficult. Wet a fingertip and touch a corner of the paper. The print side will be tacky.
2. If that isn't the problem try a different paper type to see if that prints correctly.
3. If not, run a nozzle check and cleaning cycle.
07-20-2024 12:41 PM
Thanks, John Hoffman. I verified that I was printing on the correct side, and I also tried printing on Canon Photo Paper Pro Luster -- sadly, I had the same result. I'll try your other suggestions now and let you know the results.
07-20-2024 01:21 PM
I ran a nozzle check (which looked perfect), and ran a cleaning cycle, but the results were the same. Please take a look at the two images I've uploaded below. I printed the first image two days ago, and the second image today, both on the PRO-100 using Print Studio PRO. Any ideas?
Printed 2 days ago and printed today
07-20-2024 02:10 PM
If that is on Pro Luster paper I don’t have any suggestions. If it’s matte paper I have seen results like that when printed on the back side.
Can you try printing directly from your photo software.
Are you on a Mac? If so maybe try reinstalling the driver. And beware of the AirPrint driver that can get installed inadvertently.
07-20-2024 02:46 PM
