03-26-2026
09:45 PM
10:13 PM
StevenMOD
Win11, Pixma Pro-200. Printing on label stock. Prints about 6 inches of text, then fades to nothing, then prints bottom inch or so. I've "cleaned the printer heads" but the test says it isn't necessary. Cleaned the roller.
03-26-2026 11:13 PM
03-26-2026 10:13 PM
Does the printer print properly on plain paper? This sounds like a transport problem. Is the label stock within specs for use in this printer? Too thick/stiff?
03-26-2026 10:44 PM
Don't know. Cleaning heads printed fine. Will test
03-26-2026 11:13 PM
Used plain paper and top feed. Both worked. Thank you.
