11-07-2020
09:51 AM
09:51 AM
I have a PRO-100 printer. I need to do mirror printing so that I can print on transparent paper. The only way I have been able to figure to do this (other than manually flip the image in Photoshop) is to change the Media Type to T-Shirt Transfer. This does work, but only allows a "Standard" print quality (the others are grayed out).
Is there any way of doing this that will give me maximum print quality?
george
12-11-2020 02:08 PM
Hi GLSmyth,
You are correct, the only way to increase the print quality would be to flip the image in Photoshop first, then print it.
Adjusting the print quality when using the T-Shirt Transfer setting is not available.
11-11-2020 07:10 AM
So I guess the answer is "No".
12-11-2020 02:08 PM
Hi GLSmyth,
04-13-2024 07:04 PM
I have a MG3022 inkjet. I couldn't figure out how to print anything in a mirror image. Then I found a picture I absolutely wanted to transfer to a cut and sanded piece of 5/4 (5 quarter) board. So, I downloaded the picture to the pictures folder and at the bottom of where you agree, there is two sets of arrows. Click the arrow that is pointing horizontally.
