06-14-2026 10:38 PM - edited 06-14-2026 10:43 PM
For the last month my new PRO-1100 is producing ink spots on one out of three prints, usually in the margins at the beginning of the print's run (see photos). I print on cotton rag fine art paper up to 17"x25" via the manual (back) feed. This problem is getting very expensive in time and materials.
Ink spots on 1 out 3
Ink spot on 17x24
06-15-2026 08:23 AM
Sorry to hear you're having trouble finding support for your PIXMA PRO-1100. This is a social media support site. and Canon's excellent printer team is available Monday through Friday from 8am to 8pm (ET),and can be reached at 1-800-OK-CANON (800-652-2666).
Please be sure your printer is registered first.
06-15-2026 08:37 AM
Thank you for the Canon Support contact info! I will give them a call today.
06-15-2026 03:01 PM - edited 06-15-2026 03:04 PM
Contacted Canon printer support and found out that ink spots on the prints is NOT a recurring issue known for the PRO-1100. So it's unique to my copy.
The tech suggested turning on "Unidirectional" printing in Prof Print & Layout to see if that helps. Will also try other papers to see if paper type is related. Will report back on what I find out.
Anyone else have this problem? Anyone willing to guess on a solution? Thanks!
06-15-2026 07:29 PM
Someone with a PRO-1000 had a similar problem, but didn't post a solution - https://community.usa.canon.com/t5/Professional-Photo-Printers/Pro-1000-Ink-Puddles/m-p/509216. I would guess a clogged black nozzle. Canon could recommend the proper cleanings and hopefully you can limit it to black. If you're not already printing a nozzle check ever week or so to keep the nozzles clear I would recommend that. Sorry, but I haven't seen the problem nor the fix on mine or on this site.
06-15-2026 07:42 PM
Thanks. I do nozzle checks every two weeks, even when no evidence of a clogged nozzle is showing up in my prints. For a while I thought just the black ink was spotting, but then noticed (see photos from original post) other colors showed up, usually the dominant color in the image.
For sure, ink seems to be building up on the print head nozzles and then it seems to "shake off" at the end of the print head run when it reverses direction. Could be the reason for most of the spots showing up at the margins of the image.
